liveforphysics
100 TW
Nice build!
sn0wchyld said:justinasp said:nutspecial said:The other pics look more like an 8" rear to me- so possibly to be determined, as the jackshaft should be tunable for optimal final gearing (and physical size). The motor doesn't look like an outrunner. . . .?
Indeed, the sprocket is yet to be determined, we wanted to try the bigger one for the torque. It is outrunner now, working on in-runner alternative
something custom, or off the shelf?
brumbrum said:I have a couple of questions,
will this be available to buy as just a frame and drive train combo. Most of us riding off-road bikes like this already have the the rest of the bike parts. I.e forks, brakes, wheels etc.
And, will this motor type, either inrunner or outrunner be compatible with the adaptto comtrollers? I cannot see why not.
Thanks
Andrew
1abv said:Cant wait for these units to go live! looks pretty rapid and well made..
bionicon said:If I may guess ,I think its the hacker Q150 motor inside with the HST-350 controller??
scrambler said:Just found out about this very exciting bike, congratulation on a beautiful design!
I hope we will have more information soon
Can you tell us if the bike will have a Pedal Assist mode and if yes if it will be torque sensor based?
Also does it have any regen functionality? ON/OFF or proportional? On a separate button or lever or on the brakes lever?...
Thanks
macribs said:Seems the pear controllers are some serious controllers. Look forward to see your custom version.
Have you tested @20 kw yet? The 160 pro how heavy is it modified?
LI-ghtcycle said:Not sure how I missed this build before, I LOVE IT!
Trellis style frames are my favorite!
Hope to see them being demo'd in my neck of the woods soon! 8)
justinasp said:scrambler said:Just found out about this very exciting bike, congratulation on a beautiful design!
Thanks
Thanks scrambler! More information is coming as we are building new website for everyone to understand Neematic better. Pedal assist mode might be coming in the future, what we have developed now is direct transmission from motor to the wheel.
And sure regen is there already, proportional adjustment. It will be on a separate button but glad you asked - what is your preference? Let us know more about your experience. We are still discussing many usability elements and collecting feedback.
Tyro said:Maybe you didn't noticed they will use pinion gear drive in BB. So you can select gearing for comfort pedaling. I had test ride with neematic already, so I didn't thought about pedaling with so much power and torque
macribs said:Tyro said:Maybe you didn't noticed they will use pinion gear drive in BB. So you can select gearing for comfort pedaling. I had test ride with neematic already, so I didn't thought about pedaling with so much power and torque
so tell us more about your test ride. What kind of power does it put out? It seems Neematic might do various peak power versions. Initially it was all about 20 kw mid drive. But I know they also got a 15 kw version.
How was the Neematic compared to other hi powered builds? Most common is hi power DD hubs. Did you find the benefits of no heavy dd hub motor to be very easy to notice when riding? I mean how did the bike handle sharp turn ins, wash board bumps, and quick turn at high speed? Feedback from the rear suspension? How easy was it to feel the advantages of centralized masses? I mean no heavy hub in the rear, motor low in the frame. Less prone to kick back/up the rear wheel fast and hard when hitting big bumps at high speed or multiple big bumps in a row? Did you get to do any jumps with the Neematic? How was it in the air compared to dd hubs? And how was the landing?
