Doctorbass
I discovered the new Robbe POWER PEAK E1 charger.
This is like the new high end version of the Megapower 12s cahrger.
It feature more interesting caracteristic like showing output power, Wh, %, charge 315W 20A and discharge up to 160W 40A!
this cahrger can charge a normal 16s LiFePO4 battery too ( it charge up to 63V)
It need a 35A power supply on 12V.
Here ist is:
http://at.robbe-online.net/rims_at....late/1/?ISID=4acec35000eec2ca271b3e0dc14606ae
http://www.flyoff-modellismo.it/index.php/shop/detail/279/robbe---power-peak-eternity-.html
The following battery types and cell counts can be charged:
1 - 36 NC cells
1 - 36 NiMH cells
1 - 12 PB / lead-acid cells (2 - 24 Volt)
1 - 14 LiIo (3.6 V), LiPo (3.7 V), LiFe (3.3 V) cells, plus special voltage.
In addition to the Charge, Discharge and Cycle modes the charger also provides different charge processes to suit the various battery types.
For Lithium and Lead-Acid batteries the charger operates using the CC-CV charge and cut-off process.
In the interests of safety it is possible to monitor and display the temperature of a battery during a process; it is even possible to terminate the charge automatically at a particular pre-set temperature; the appropriate sensor is supplied as standard.
Future-proof: Flash memory technology is the key. Software expansions can be loaded in the form of upgrades. Alternatively the charger software can be updated to cope with new battery technologies.
Rapid developments in Lithium battery technology mean that new battery types are constantly appearing, all with different charge and cut-off voltages (Lithium-Ferrum, Lithium-Phosphor, etc.). The Eternity charger is already prepared for these changes, as it features a special menu with a variable set-up facility for the Lithium battery voltage. This means that it can be adjusted within broad limits to suit new Lithium battery types and their cut-off voltages.
The charger features a USB interface for connection to a PC. The excellent free PC software "Logview" is now well known, and can be used to process the data from the Eternity charger for recording, storing, comparing and printing. The charger also features its own internal memory, so that data can still be recorded if no PC is connected to the unit, allowing the data to be read out and stored at any subsequent time.
The charger features two independent charge outputs, intended for drive and flight batteries
Quiet, temperature-controlled cooling fan.
Cell count: 1 - 36 NC / NiMH cells, 1 - 14 LiIo, LiPo, LiFe cells, 1 - 12 lead-acid cells, 2 - 24 Volt
Charge current: 0.1 ... 20 A (max. 315 W)
Discharge current: 0.1 ... 40 A (max. 160 W)
Equalizer current: 250 mA
Cut-off method:
NC / NiMH batteries: automatic, digital Delta-Peak system with variable Delta-Peak voltage
Temperature cut-off: 10 ... 65°C, variable in 1°C increments
Lithium / Lead-Acid batteries: automatic, using CC-CV process
Cut-off method
LiPo: automatic, using CC-CV process
Protected against reverse polarity and short-circuit
Sockets for: temperature sensor, Equalizer, BID key, USB.
Doc
Here ist is:
1 - 36 NC cells
1 - 36 NiMH cells
Cut-off method:
Cut-off method
Doc
