Deepkimchi
Maxwell - what type of charger you had that fried ?
Fixed mine for about $30 bucks of parts.
Bryan
Bryan
Deepkimchi said:I still can't understand why you put so much effort into something to sell and then post the schematic. Why not just PM it to the few individuals that might have a valid interest (and actually understand).
If someone buys the board, like me then you could include the schematic with a description of how it works, critical voltage points, as an "owners manual".
I really think you should protect your investment and hard work.
PJD said:What happened?
maxwell652000 said:also what is the ideal cell voltage of lifepo4's when it is completely charged,,,3.2v/ 3.3v /3.4v?
DavCbr said:I'm new here, ... does anybody here have any idea if my contoller COULD handle the 16 cells, which I would prefer anyway. I ride this to work each day, and I'm often running late. Any extra speed would be nice.
dc
Ypedal said:DavCbr said:I'm new here, ... does anybody here have any idea if my contoller COULD handle the 16 cells, which I would prefer anyway. I ride this to work each day, and I'm often running late. Any extra speed would be nice.
dc
Hello Dave.. yes.. your crystalyte controller will take a 48v pack .. charged up to 56v no problem .. ( well. sometimes they blow up.. but i've done this many..many times over with 16 cells without any issues.. ) :wink:
Randomly said:Looking good. If you need a higher current relatively cheap TO-92 PNP the KSB1116G or KSB1116L parts are good. They maintain high beta even past 1 amp.
I would like to know what connectors exactly that you are using? thanks.
GGoodrum said:I think those are the ones that we are switching to, but I'll check. I think the shunt one is a tall TO-92?
-- Gary
Randomly said:The KSB1116 is in a regular TO-92. I'm sure whatever you're getting will work fine, it's a very noncritical part. As long as it can handle the current, the LM431 can supply plenty of base drive. Using a TO-92L package with it's larger heat dissipation capacity can't hurt either since the transistor is going to be operating in the linear region and dissipating some heat. At the worst case bias point the transistor will need to dissipate 1/4 of what the load resistor will dissipate when it's put across the full cell voltage. Don't pack it in too tight, and any extra PCB copper area you can afford on the Collector pad will help some also. You can always scale back the balancing current if you end up with heat problems.
MagicBob said:Sorry if I've missed this, but how do I order one?
