arclarke said:
I looked up your description of this (page 64 - excellent write up). Does the micro switch only activate when shifting one direction, ie to a larger cog? I'm wondering how this would fare with an Alfine 8 speed hub. Is there mileage in a cable movement sensor activating this throttle cut-out instead of the brake one?
I have an Alfine hub on mine and have found the same issues as Kepler with delays. The simple stop peddling to change works well enough however the delay is very annoying particularly when pushing hard up hill.
I started using the throttle method which is much better with no delay however if you apply a bit to much throttle you will crunch the hub, lucky for me I'm no fan of a throttle and ride on PAS only 99% of the time.
So today I got into the software and set my throttle to the exact opposite as normal, locking it to assist level 0 and also setting assist level 0 to just 1% current. With my throttle mounted on the left this setting works perfectly cutting the power for gear changes on the right in either direction with very little delay and without having to do any wiring mods. Down side is no throttle however I never use it any way.
A 2 button set up on the left would be better 1 for kill and 1 for full however that's hardware mods and I'll spend a bit of time with like this before I commit to cutting wires.
