Well, after two months in the making, here it is:
The Ultimate thrill ride on three wheels. Without pushing it much it got up to 46 mph... So, once I shunt the controller and push it harder it will will most likely shatter the 60 mph barrier... the magic number!
This was not a "simple" lets bolt a Cyclone 3000W motor onto a KMX trike; I could've bolted the motor to the trike 2 months ago in one afternoon and be done with it, but that would've been too easy; besides, I wanted to prove to those pesky Bafang snobs that you can build a Cyclone 3000W bike/trike that doesn't look like a gawd dang contraption... Instead I set out to design and build a road worthy tricycle that doesn't look like a roll of duct tape on three wheels. This trike has every amenity you can think of (well, except air conditioning, unless you count 2/60 AC??, sorry no heated seat either...
), bluetooth? got it, turn signals? got'em, 6500 lumen headlights? got'em; 1200 lumen taillights? check... Luggage compartment? got one; USB charger? chalk that one up. A horn? yup, is got one, and a freaking loud one... Alarm? you betcha. Not installed yet but it will have a Scorpio SR-i900 with proximity sensor. Nobody is getting close to my trike without me knowing. I am already in talks to Adam to purchase his front suspension kit for my trike; and although it wasn't too bad at 46 mph, I can see how it would improve the ride on rough roads.
At 21 Wh/mile it will do about 120 miles on a charge... which is double of what I hoped for, on my initial calculations I was accounting mileage using the 46 Wh/mile of my eBike... I guess this thing pierces the air real good with the fairings I built.
Everything in this thing uses solid state MOSFET switches, motorcycle grade turn signal gear and solid state fuses. It has three voltage regulators and in case of failure other regulators can be rewired to take over the duty of the main 12V rail. Everything in this thing has been thoroughly thought out... I also built a HOTAS (for those who know about military aircraft) for my left hand. Which once I finish hooking some of the extra stuff it will also control the Cycle Analyst from the HOTAS so I don't have to bend over to operate it. I already laid the wiring for it, I just need to get it done; but everything just takes time... dang it.
The charging solution right now is done using a DB25 cable for the balancer, but truthfully, there is no point in fully charging the pack ever... really, with 120 miles range is pretty much no point, so I might just charge them in parallel at 300 watts with the LiLo (4.10 per cell) cutoff voltage and be done with it.
The motor mounting solution is totally custom: I will explain with more details how I did it but this was definitively not your average Cyclone 3000W install. It took almost 16 hours of work to settle for a bulletproof mounting solution.
You can see the cowling where all the electronics are stored inside. This will help with rain and most of the road crap in winter.
Another angle
Some close up of the HOTAS (Hands On Throttle And Stick)
And here is me ready to enjoy the first ride... I couldn't wait to feel the beast for the 1st time!!
On the road... woohooo...
Checking the CA after the test ride... just wow... (Yes I know, I love five finger shoes... )
VIDEO RUNNING:
https://www.youtube.com/watch?v=lArVKGgkwTo
VIDEO OVERVIEW:
https://www.youtube.com/watch?v=oFC8MRwvgUM&nohtml5=False
Enjoy, more updates as they happen.
G-man.
