gman1971
- Joined
- Oct 17, 2015
- Messages
- 976
I purchased a GNG new for 2015 called Gen2; is a converted hub motor into a mid drive, thats the kit I purchased. It was called Gen2 GNG 2015.
G.
G.
emaayan said:gman1971 said:Motor on the GNG Gen2 was run with the stock controller, which peaked at ~1200 watts with freshly charged LiPos. I think I was considering shunting the controller at some point, but after speaking about it with you I never did. To run the motor at anything above 1.5kW it would've needed more like 32 amps, and the controller topped out at 22 amps IIRC, at least thats according to CA.
I remember you recommended me the Bafang and hub motors, I don't have recollection of any mention to the Cyclone... regardless tho, I was total noob then. I didn't have much of a clue about what made a good eBike and after sinking 320 dollars on that GNG kit I figured I had to try to at least make it work... In the end, I got tired of that POS breaking all the time so I tried the Cyclone, but I was one inch away from purchasing the BBSHD... I also got fed up with their customer service (or lack thereof) so that was the straw that broke the camel's back. What I knew tho is that wasn't keen on hub motors. And for the record, few days after the motor came out of my bike I took it apart and fixed the slipping clutch with a drill press and some metal plates, so the kit should work if I was to install it on another bike.
As for the pictures that you've showed, that's not the motor/kit that I have; but the plates look like they have a strikingly similar thickness of my Gen2 kit... fairly thin IMO, and on mine they are not countersunk... so they can have interference with the chainring...
I am willing to accept I might've made a mistake messing around too much with the GNG, but in the process I learned a lot... about bikes, and about ebikes... however, I am not picturing what your problem is tho...
FYI, the eBay 24V brushed motor that you warned me it was going to be total waste of time turned out to be a decent kit after all.... Works very well, and it only took me about 4 hours to install it and the only mod I had to is add some side adjustment holes to the motor mounting plate to allow for lateral movement and get the motor lined up with the chainring. As of today its been absolutely rock solid and my son has clocked about 200 miles on it running it on 12S LiPo @ 48V and it goes up to about 28mph on his 24" Roadmaster mtb. Is not Cyclone quality/power, but it has worked out to be a much better kit than Gen2 GNG.
G.
that's what i thought, i had question marks when you started referring to gng 2015 gen2, as there is no gen2 for the 2015, so everything you've experienced is related gng gen2 (no 2015) , the 2015 has no upper plates, it's jackshaft is held in a horizontal arm which is part of the motor casing itself, this is what i mean by superior, additionally the lower brackets are also strengthened by a middle arm in between them. those have not bent or broke (known on wood).
