I've been tearing my hair out trying to decide if I should send my new 26f pack back for the 25r pack (lose original $57 in shipping plus pay $90 more for the "better" battery).
They both may have the same BMS, but the 25r's characteristics are very different than the 26f's.
If you drain the 20 Ah 26f pack at 40.8 A continuously, its effective capacity will be reduced to 16.32 Ah. The 26f's spec sheet states that a 2C drain rate will result in an 80% capacity.
If you drain the 20 Ah 25r pack at 80 A continuously, its effective capacity will be 99.2% of its 0.2C capacity. Basically, the 25r pack's effective capacity is the same as its advertised capacity even at relatively high current levels.
The 25r should be able to hold a higher voltage under load as well, delivering higher watt hours because even if a pack can deliver a certain Ah, the pack that can deliver that Ah at a higher voltage will allow you to go faster. The 25r has much less internal resistance, so less energy will be converted to heat.
Now how much of this matters in real life I don't know because I know I won't draw a 40A load continuously, so I don't know if I'll notice any advantage using the 25r pack.
Also, the 26f pack with 8 groups in parallel, is rated at 40 amps max, so if you're pulling 40 A, you're at the limit of the pack, while the 25r pack is loafing along at 25% of its maximum 160A ability.
https://www.powerstream.com/p/INR18650-25R-datasheet.pdf
http://www.oomipood.ee/kasutusjuhend/ICR18650-26FM.pdf
DingusMcGee said:
robocam,
the specifications for my battery from Luna are:
50 amp continuous 80 amp burst BMS
I suspect the OEM controller was limiting output to 40amp.
Do you think a 25r-based pack would have given you a significant performance boost?
the Samsung 25r pack specifications state:
To get more from the 25r you would have to change the BMS. But worth asking, "Are the 80 amp bursts the same for both batteries?"...
