k9kruiser
- Joined
- Aug 17, 2016
- Messages
- 16
For many years I thought I would end up on a trike for a variety of reasons. I have seen several people use the Schwinn has a cheaper alternative to a Workman and that fits my budget better for now.
I looked at a motorized hub and then a gear reduction motor to connect to the rear axle, and almost went that way, and now I am back to a hub motor in front like most others have done.
1. There are some cheap 1000W/48V kits that get good reviews. Considering I am a heavier guy and a load of batteries, etc. I thought I could use the HP.
2. the specs say they need at least a 17AH battery. Almost everyone in the reviews said they were using 10-12AH batteries? If you have 48V, doesn't the extra AH only affect distance or is there a draw rate or something the 1000W needs that it can't get with a 16AH battery?
3. I know the Meridian has bad rims, spokes, and tires out of the box so I expect to change those, and of course the front wheel will come with the hub motor.
4. the motor kit I think comes with a 3-speed throttle, i.e. 3 buttons...can a twist throttle be used instead to give you variable options for speed?
The bike is arriving Thursday and I will begin prepping it, i.e. battery box, etc.I would love to know if 20AH is necessary, and if not, probably suggested. I am not sure if I can afford LiPo at this point so might start out SLA but 48V/20A SLA is about 52# vs. 16#
Any other starting out hint, suggestions, etc.....the Meridian is the given, the rest is still up in the air..
