El_Steak
A friend bought a 9c front motor for his Haro BMX.
The BMX fork is all steel and very heady-duty. It is 100mm wide which is enough for the motor, but not for the 2 thick inside washers. Since it's short and very strong, the fork is very difficult to spread to allow the washers to fit in.
The dropouts on the fork are made of steel, they are thick and perfectly flat. The motor axle is a nice tight fit in the drop out.
In that case, are the inside washers still essential or can he skip on them?
The motor is a 12x5 in a 20" wheel and will be run at 48 volts / 35 amps. (A torque arm is included of course)
