Propofolboy
Hi everyone.
I'm pretty new to this and a bit disappointed this morning.
I installed a 1000W hubmotor on my front steel fork of my fatbike a couple weeks ago, and thought I'd done a good job. The spacing was tight, so I wasn't able to put any washers between the inside of the dropout and the axel shoulder of the hub motor (it has quite a small shoulder I now realize). On the outside of the dropout I installed a c washer, then a 1/4" stainless steel torque arm bolted to fender eyelet, and an axel nut on BOTH sides. On the non wire side of the hub motor I used a torque wrench to 60 N.m. On the wire side I just used a crescent wrench, and probably only 30 N.m.
Things had been going well until yesterday I checked the axel nut and they were loose. I decided to take the whole setup apart to make sure nothing was wrong. I hadn't had any issues at all riding the bike (no spinout or anything). To my horror I discovered that the inside of the dropout on the side I torqued to 60 N.m had become damaged. It looked the the shoulder of the axel of the hub motor had dug into the bottom of the dropout, spread it out about 2 mm and distorted the metal. The top 60% of the dropout however was fine, only the bottom had spread out. The other side dropout was perfect, no sign of spinout or anything. The two torque arms were also perfect, and very snug on the axel (no sign of spinout).
My impression was then that the torque of the hub motor had not created any spinout despite having only hand tightened nuts for at least a few of my rides, but the process of torqueing the axel nut had created a wedging effect and spread out the one dropout and slightly damaged it.
My solution which I spent last night doing was to slightly cold set my forks about 4 mm wider so I could now place two heavy 2 mm thick washers inside the dropouts between the hub motor axel and the (slightly damaged) dropout. I filed the dropouts about 0.5 mm deeper. This created a pretty tight fit. I then put the c washers, torque arms and axel nuts on the outside. I then put on some Loctite and torqued it up to about 40 N.m. Everything now seems very solid, and I don't think the inside of the dropout is being spread by the axel shoulder with that heavy washer protecting it and providing more surface area against the non-damaged part of the dropout.
So I guess my question is -- is my slightly spread out single dropout going to be a problem if I now have everything tight. I read Justin Le's 8 page thread on spinout and forks with great interest. The takeaway from it seems to be that if there is slight play between the axel and the dropout its not a big deal as long as you have torque arms and tight axel nuts to provide friction. He seemed to indicate that really the dropouts are not that important to prevent spinout and talked about even rounding out the axel on the dropout so it would spin freely to test how well the torque arms and friction protect the system. Indeed just the dropout alone with no friction or torque arms really provides very limited spinout protection (like less than 20 N.m at best). It is a bit reassuring to me as well that despite the damaged dropout, and only hand tight nuts there was absolutely no signs of spinout to the two torque arms or the other dropout that I hadn't tightened as much...
Thanks!
Thanks!
