Long John Rider
100 µW
- Joined
- May 9, 2016
- Messages
- 9
Hi! I registered here since this seems as good a place to do EV research as any. I am not wise to the ways of the electrons, but I am trying out of necessity. Bear with me if you have the patience.
I am currently using an extensively modified, very old and very heavy two-wheeled cargobike as my primary mode of transport. About six months ago I went electric, got a brushless front wheel hub motor, gearless, 500w 36v. It came from a busted 28" wheel but is now mounted in a 20" rim. Both motor and ESC are run of the mill cheap Chinese stuff, so no regen capability there. The battery is 20Ah according to the seller, and I’ve never been even close to running out of charge the way I ride. I am very happy with the performance of the bike as it is but the upgrading is still not complete:
My mechanical brakes get hot to the point of potential brake fade under certain riding conditions. I would like to augment them with an electrical braking system. I am not particularly interested in charging the battery when braking, I would be perfectly satisfied to dissipate that energy of into the atmosphere with the least amount of fuss. I don’t need an additional emergency braking system, I want an undramatic way to gradually slow my speed for descents and planned stops that transports a meaningful fraction of the heat to somewhere other than the mechanical brakes. I also find the idea of braking without mechanical wear to be aesthetically pleasing.
The plan: Using a 40 amp three pole double throw relay to isolate the motor from the ESC and connect it to an array of electrical loads instead. The resistance could be made variable in two or more increments using additional relays, or something, should it prove useful.
Questions for those who know more than me:
-Is my plan at all feasible? If not, why not?
-Is it possible to get any meaningful amount of braking from a motor such as mine, at least at higher speed? How much braking force can I expect? (I want most of the kinetic energy to be converted to heat outside the motor rather than in it. I have been told that this type of "efficiency" affects how much braking can be done, and what type of resistors to choose.)
-what type of resistors; ohms and watts and so on? Delta or Y connected? My current plan is three wound resistors with heat sinks/cooling vanes, but I haven't quite given up on light bulbs, since that has the potential to look cool.
-fuses: assuming I go ahead with the plan and start experimenting with resistors, what kind of fuses would be prudent on the braking circuit to avoid burning up the motor should I mess up. Or am I being paranoid here? Would it be potentially bad to lose just one or two of the phases somehow?
From what I’ve read on these boards so far, I guess I could just get a fancier speed controller and be done with it, but this of mine plan seems more fun, more educational for me, cheaper and potentially good enough since I’m not really after the modest range increase regenerative braking might offer.
Any informed input would be greatly appreciated.
