Timma2500
This bike was my 1st ebike build some years ago but due to the Banebots planetary gearbox constantly breaking, it didn't last long before i sold off the Astro 8150 i used and built another bike using a more reliable Cyclone system.
The time has come to start rebuilding the bike along similar lines but with a few key changes.
Specs: C80-100 130kv motor (unmodified), HV140 esc, 12s lipo 12 or 15ah lipo, CA RC current limited to 5kw, Neugart 5:1 planetary gearbox, TryAll ISIS 170mm trials cranks, 128mm Truvativ DH bb, Eno crank freewheel, 2 x 34t crank chain rings, 11t-34t Shimano XT 9spd cassette.
Frame details will include scoops for motor and esc cooling, internally mounted CA and internal cable routing an extended wheelbase to 1200mm
Driveline will consist of primary HD #25 chain and 25t / 40t sprockets, the 5:1 PLE80 gearbox, 14t / 34t Cyclone freewheel to cranks.
I could have used smaller #25 sprockets but chose to keep the tooth count up higher to minimise wear on the smaller motor sprocket.
It will also have an idler / tensioner to maximise wrap around on the motor sprocket for the same reason.
Gearing will be higher (19.428 : 1 total reduction) than the original bike and the Cyclone bike for a few reasons. I won't be doing massively steep hills with the bike due to the HV140, i don't want to load it up at slow speeds. Secondly, i noticed with my other chain drive bikes that they suffered from chain skip in the higher gears over rough ground at highish speed due to the low tooth count in 8th and 9th gears. This time around i'm gearing it to get the same speed in 6th gear (17t) that the others did in 9th gear (11t). The remaining 3 gears will be used for chasing Kim when he finishes rebuilding his cruiser :wink:
The downside is i won't be able to match cadence with the motor at its higher rpms but thats fine
Speed in gears at WOT, based on 85% no load motor speed @ 47v:
1st: 32kph / 20mph
2nd: 36kph / 23mph
3rd: 42kph / 26mph
4th: 47kph / 29mph
5th: 54kph / 34mph
6th: 64kph / 40mph
7th: 73kph / 46mph
8th: 84kph / 53mph
9th: 99kph / 62mph
I'm now sorting out frame details and should be starting the chop next week or the week after.
Target weight will be 23 - 25kg with 12ah.
Paul
1st: 32kph / 20mph
2nd: 36kph / 23mph
3rd: 42kph / 26mph
4th: 47kph / 29mph
5th: 54kph / 34mph
6th: 64kph / 40mph
7th: 73kph / 46mph
8th: 84kph / 53mph
9th: 99kph / 62mph
Paul
