MaddieJane77
Hi i live in phoenix AZ and have been wanting a bike. well my friend shows up and says i found you a e bike for free he open his back door and wrestles out a Voloci almost complete missing a front wheel a batt a chain and the cover for the controller i have temporally mounted a bike wheel to the front so its mobile i happen to have a good 36.0volt lith ion batt from a razor metro sup that fits perfect I need to know of the three contacts in the batt box which one is pwr/grnd/ batt temp. i got the controller wires all hooked up from pictures on this site. but the 12volt system aka the lights and switches lead up to the bottom of the seat most i figured out except where does pwr come from i take it the key switch wires can just be jumped as no key was with id like to get this electric hooked up and see if it works sooner rather then later if the motor is bad which it maybe as the hall senor wires are super stiff and the main pwr to the controller had the connector welded onto the inside of the cover at some point. can anyone post pics of the wiring under the seat it much faster then trying to remember how to read wiring diagrams when i know pic would be faster. if i can keep this bike original I will do that but if not i got a razor es300 brushed motor and controller 32.v but i know it will do just fine with 42 volt batt. i plan to go that direction only because i just escaped homelessness and have no income but to have any transportation in the arizona heat is a blessing and this bike is so light weight and bike like i can put it in the bike rack on the bus easier then many bike users but id be grateful for any positive feedback advice or help offered in advance. also ive notived my seat has a metal platform i have not seen on any others id be tempted to mount a mobily scooter motor seems like a good spot for motor and battery and would keep it much cooler. i know this bike has the potential to be faster then my CBR 1100XX but how frightening or stable is this bike at very high speeds just wondering just after around town transportation. anyone have a good way to keep from walking off while one is shopping??
thanks Maddie
thanks Maddie
