My set up is a QS205 V3 3.5T motor, 20s15p 30Q pack with a 24F controller. Did auto set up, saved settings and road around for about an hour 2 days ago. Worked excellent. Disconnected the battery when I was finished. Plugged the battery in and closed the cover. Twisted the throttle and the bike shuttered & wheel turned backwards? WTF? Tried to auto tune and motor was fine, did angle correction and motor just stayed still and couldn’t be turned. Timed out! Kinda clueless as I’ve never had this happen before with any controller. Figured it might be halls even though the second set has never been used......I tried to run sensorless. Never tried sensorless on any controller and it’s sluggish. If feels like it’s never in sync. When I turned to the halls screen and rotated the wheel it went in order from 6,5,4,3,2,1,6,5,4,3,2....... any ideas?
Also the left button decided to stick and wouldn’t work. Apparently this one has a bad mold on the switch plate. I was able to bend a bit to get it to work but most probably will need to be replaced. The small lip at the top slips off the switch.
