I like that you keep challenging my pre-conceptions. It's fun being challenged and I enjoy exploring new concepts.
But I think we are coming at this with very different goals and so thought processes though.
I want something I can get on and ride this lifetime - ie in the next decade. I'd like to nudge things a tiny bit toward increased electronic control of what's currently done mechanically - if that's of real world value. Mostly just for the sake of it.
You are exploring what is possible given access to the right hardware, and software engineers who know what they're doing. I'm not sure I've got access to the first & I in no way resemble the second!
The theory of what you can do with an electric motor and capable controller is all great, and I'm willingly accepting you know what you're talking about, which you'd have to agree is verging on gullibility in a public online forum.
But your early comment about dumping yourself on your arse with a burst of power makes me wonder a couple of things.
Do you understand why you went off the back?
You didn't go off the back because there was too much torque/power applied. That's absolutely certain without me knowing anything about the bike involved. It could be the world's fastest electric drag bike for all I care - the fact remains the same.
The other is what understanding/knowledge/experience do you have on a trials bike?
It's not at all a pre-requisite for valuable input into the problem, the more skills and knowledge brought to bear from a wide area the better. But it does point out where there is actual knowledge about the problem and where it is simply ideas being floated that need assessment by an expert (I'm not an expert trials rider, let's be very clear).
This is where the line I quote below suggests you may not be grasping the problem from a complete understanding of the desired outcome. Power is not the issue here, trials bikes are gutless quite intentionally. And that's disregarding the fact that the power of a trials bike engine is really only a part of the total in the clutch-dump power.
It's the control the rider can exert over the power and the nature of the delivery that's critical. There's a fine line between automation helping and hindering.
They totally beat any IC engine of comparable max power.
You cannot power very well a MC with hair clipper motor regardless of the size of the controller and batts.
To an extent I'd argue the toss with you on that one, a hair clipper motor that spins to a zillion rpm and a decent flywheel could be surprisingly capable for certain trials conditions. If you've ever looked at what a skilled rider can send a 125cc trials bike over you'll see a case in point. Those things are seriously gutless, a Honda CT125 posty bike isn't too far out of the ballpark. But they sit there WOT until the thing's at absolutely max rpm then drive off the flywheel, sending the bike and rider up massive obstacles. They hit their limits if there's a sustained hill though.
But yes, you're mostly correct, and that leads me to this:
The idea of using the motor to supply all the power seems to me to lead into a mass:benefit problem.
If I choose a motor that at saturation provides me with sufficient power for all my sustained power needs then it's not going to have anything available for the big bursts. So now I add more copper & iron and a bigger controller (or indeed a second one) to get the bursts.
That bigger motor probably also needs a bigger battery to supply the additional current while retaining the target duration capacity.
And all that has to fit into a fairly seriously volume constrained trials bike.
How many kg does that add up to vs how many kg does a flyweel weigh that provides for the burst power?
My guess is that it's at best even, and maybe the flywheel might win.
And we haven't even started looking at the actual rider/machine control interface and how it all interacts.
If you don't ride trials (do you?) you may not realise how finely tuned clutches are on trials bikes. They vary individual plate thicknesses by fractions of a mm, use a variety of low viscosity oils to get the feel they want, adjust the diaphragm springs (coil sprung clutches are dinosaurs for trials) in tiny increments ... This all to get the exact feel the rider needs to perform at their best. It mostly makes no difference to the measured characteristics of the clutch - it releases cleanly when asked and locks up when asked. It's the bit in the middle that they are working with.
Pro riders will sometimes travel from country to country with their favourite clutch pack and rear shock in their bag, throw them on a stock bike and race. They wouldn't dream of racing on the stock shock & clutch, but the rest of the bike - whatever, maybe change grips and pegs to their preferred ones.
So the electronic version had better have some pretty good advantages. It might well have, but
assuming it does certainly doesn't cut it.
Your posted color graph without a time axis cannot show rise rates of a given motor/controller/battery system outputs — useless.
What? The time axis is time, as it passes us by, right now.
My interpretation of the proposal is that as you manipulate the controls in preparation for a launch at an obstacle the colours and amplitudes reflect the state of the control. The time scale is that you can watch them change, in real time, right in front of your eyes. So stating "useless" isn't true or helpful.
Having said that, my eyes are fully occupied when riding a section - no way I'll be looking down at the bars just before throwing myself at a scary obstacle!
We've got four senses, let's use more than two of them. Ears are good jiggers, I find them generally quite useful.
