dan974
crossbreak said:I could test the Kelly now. Does not work as expected. The most reason i bought it was that it has "Torque Mode Throttle" available in Setup. But that is no real Torque mode Throttle. It's a Speed throttle. It's not as twitchy as the Infineons and X8m06c Speed throttles, but still no torque throttle An Infineon with a good throttle mapper/tamer isn't worse than this.
BUT what concerns me most: If i let go the throttle (zero throttle) after Full Throttle , it does NOT REDUCE TORQUE INSTANTLY!!! WTF???!?!? Even the cheapest controllers response faster on Zero Throttle
I programmed it to FASTEST Throttle Response. What a waste of time
[youtube]xC2dfl62KZ4[/youtube]
you swear kelly controller but you did not even give all the settings to help you not even the model...did not tell if you tried balanced mode, if you adjust your throttle range (starting and ending) regarding the setup I use only 1/4 of the throttle to get the full range so I don't have to overtwist my wrist, which throttle sensor type you use in the software, max current...low and high threshold...
what do you intend with partial info ? right to Fany if you need help, we don't even know which one you're using , try to use it not with empty load...
