Bluefang
I have been thinking about doing a motorbike build with a hub motor mounted normally with a 2nd motor, driving a chain powering the hub as well. Due to voltage limitations the top speed is borderline to what i want. My question is can a hub motor be over run by 20% even with the controller at max. So under full acceleration the hub would reach max at 100km/h and the 2nd motor would keep driving the bike up to 120km/h, would the over driven hub cause a major resistance to the 2nd motor? Would it blow up the controller( i doubt this)? Would the hub cause a small resistance to the 2nd motor?
I am thinking and hoping that all i will have to contend with is the cogging effect in the hub motor and also the hub been unable to use regen until its below the controllers max voltage setting. But would like some reassurance
