HI
I have assembled the kit from PSWpower on a Q100C.
17A controller - http://www.pswpower.com/ven.php?cargo.2016-3f-39n8
I have this PAS http://www.pswpower.com/ven.php?cargo.2016-ar-3h3c 12 poles.
The throttle powers the system and everything works. However when I pedal nothing, apparently happens. I may be wrong as I have not ridden it.
the pas has 3 wires: http://www.pswpower.com/ures/dtpic/2016/AR/3H3C.3R3KN/443BSR_QC0S5.jpg
PAS set to 5.
Brown - +5V
Black - Ground
Yellow - Signal
I can tell when the motor is working as I an hear it. If I hand crank the pedal on the bike stand nothing happens with the motor. Speed sensor works as it shows the increase in speed without using the throttle and with using the throttle.
The PAS appears to be working as the red light is flashing when I turn the crank.
Troubleshooting.
a) one of the wires is loose. I checked the PAS wires and they are solid. I did have to mount a male, rather than female connector but I soldered everything and it appeared ok (heatshrunk etc)
b) The controller isn't sending the PAS as I haven't configured it.
c) Its the wrong way around. I pedalled backwards and still nothing happened.
So I am stumped here.
Edit:
I cut the cable.
If i touch the black (ground) wire to the Yellow (signal wire) The motor spins briefly. So the controller is working.
if I swap the Brown and Yellow wires there is no difference.
if I swap the Black and Yellow wires the display shows 0 battery (probably as ground and positive is reversed.)
is there a setting for the number of magnets on the pas for the LCD? Or some other configuration?
Edit 2:
its the PAS sensor. I used another pas sensor and it worked fine. However it doesn't fit my bike :-(
This one works.
http://www.pswpower.com/ven.php?cargo.2016-2v-dw8e There must be some configuration somewhere.
PAS set to 5.
Brown - +5V
Black - Ground
Yellow - Signal
Troubleshooting.
Edit:
I cut the cable.
Edit 2:
This one works.
