yeah, so if you send us a pic of your PAS connector we can probably guess the pinout, usually, red is 5v, black is GND and white/green/blue/blurple (or any other color literally) is the sense wire. A few steps.
- Make sure PAS is plugged in
- turn controller on
- get multimeter and put in continuity mode.
- connect one side to GND
- connect other side to colored or white cable( the third, not 5v cable)
hard part is having a third hand turn the pedal, you should see voltage change from 5 to 0. this is for a 3 pin wired PAS similar to throttle wiring.
if this works, then it may be a setting or your controller. if it doesnt, then either its not a 3 wire, uses some other weird method to judge PAS(or torque sensing?) or it may just be dead due to a bad all sensor in the PAS or demagnetized magnets(unlikely as this happens under high heat and PAS is probably one of the coldest components on an e bike.)
