Optimal battery will be costly, most want to roll the dice and cheap out.
ebay and amazon are your friends for ebike kits, in NA, UK, AUS, use the Ali's or your local gettup for elsewhere.
Choosing a vendor that is trustworthy would be simply using the search button.
On the battery side, same thing applies. People have been known to use tool pack batteries sold by outfits such as Home Depot, whether keeping them whole and intact, or taking out the pcb bms and doing your own MULTIPLE cell encasement, or you get lucky on EGO packs. Heck, theres still people rocking lead acid batteries, the bow legged epidemic.
Here is the low down, you must seek out information on how much power you want. Then you look at the terrain and slope gradients for x-amount of distance. We work back and forward from there, if you want to choose the optimal e-bike kit, see your thinking is reversed there. Yes the battery is crucial to. Battery size ah/wh, discharge amps, format, final dimensions, all play a big part. Or, throw the dart at ebay and hope you get a motor with your right kv/turn-count. Leafmotor, Leafbike is good, take a peek.
Fvrdol said:
If you have better option feel free to say...
What batery would be optimal?
