The Mighty Volt
zombiess said:The Mighty Volt said:I see you guys are running rear and front suspension, I am chopping some BMX frames to convert them, I recently bought two Manitou Metel-R's as they were going cheap. My problem now is with the spring rate, I figure with a heavy X5 in the rear and 16Ah 72v of A123, I am going to be running an above average weight. Does anyone here have any idea what sort of spring rate I should be looking at? Personally, I am tempted to go the highest possible, at around 800lbs. Nukeproof or Manitou were what I had in mind. Thanks.
To calculate your spring rate you at least need to know what your leverage ratio is and the loaded weight. I know on my bike I'm 1:4 on the shock as in 1 unit of shock movement = 4 units of swing arm movement so with 1" of shock travel I have 4" of rear suspension travel. If I went 1:5 I'd need a higher spring rate and 1:3 lower spring rate. A lot of this depends on where and how the shock is mounted.
Thanks, I think I will just order the heaviest rated spring and see how it goes.
What mm travel did you finally settle on for the front susp forks? I find that some 700c forks offer around 67mm travel and do not excessively raise the front profile of the bike. It seems that less travel on the forks means less geometry issues, is that generally accurate?
Thanks again.
