Hey everyone !!
Been a while, i still check in from time to time but have been super busy with life and all that jazz.... you know. .. ( Being self employed and a one-man-band gets complicated.. )
So, after years and generations of motors and controllers.... seems we are now in the age of FOC ( Field Oriented Control ) and things are now a lot more smooth and/but more complicated than they used to be !.. rip Grinfineon ...
For the most part, if you get both motor and controller from Grin, you can load a default profile and get going. .. If using a 3rd party motor the Autotune makes life a heck of a lot more convenient ( if you ever played wire-bingo in the past... yeah boy.. ) . But once you get everything functional, then comes the " Tuning " stage......
I see a lot of help threads asking for solutions to problems but not much in terms of discussions on how to optimize your rig.
Last couple years i've mostly been pairing Baserunner with Grin's SX motors, the angled gears run quiet and it's reliable at 1000w peak... good power to weight combo.
Today, i'm mixing a Gmac motor with Phaserunner v6, Ca V3, erider torque sensing PAS , and intend to use back-pedal regen on it. 52v 20ah battery.
*( a post is always better with a picture ! )
Awesome bike, and i'm not looking for a mild ride, i want this to go as much as possible on a fist full of throttle.
First thing i had to adjust was in Speed Limits.. the SLim->DSGain was defaulted to 600, this was causing the power to drop in mid rip and surge... dropped that down to 100, way better.
Next is the Output Torque Ramping, on the Phaserunner side, default to 200ms.. set to 100.. about to down to 50 ms
Now the issue i'm having is that on occasion, not always.. i get the phaserunner to error outo 2-2 " Instantaneous Phase Overcurrent " .. and this usually means having to mess with the " Feedback Bandwidth Tuning " .. and a bunch of stuff i don't understand... I'm all for throwing a number in a box and having things work but can anyone explain this to me in average joe terms ?
In the latest version of the Phaserunner Suite ( 1.8 at time of this writing ) the KP and KI values grey out when you use " Current Regulator Bandwidth " .. so one negates the other ?... PLL numbers, what's a rad ?.. lol..
