passpato
- Joined
- Jun 18, 2011
- Messages
- 89
My friends 36v 10 a/h Ping battery will not charge. It is about 5 years old now. I thinkthe BMS is stopping the current flow. I have an identical battery and I am able to test things by swapping around and/or testing with a multimeter. The Charger works ok on the other battery so I'm ruling that out. I have tested connections up to the battery and they are ok.
There is no output from the battery however . I can measure a Voltage of 28 volts from the charging input wires into the BMS and the output wires from the battery has the same voltage but when I touch the output wires together there is no spark. I think the BMS has cut output power and voltage is too low to charge but I don't really know what Im doing.
Can anyone tell me whats going on ? Is it a dead Cell ? Can I recover it somehow?
