upward
1 W
I have been reading through the forums and appreciate the wealth of knowledge and the community.
Planning my first ebike conversion to help reduce the use of my car for both commuting to work and to run errands.
My commute is:
- 19 miles one way 3 days per week (office #1)
- 9 miles one way 2 days per week (office #2)
- (Downtown is 3 miles one way for groceries)
The goal is to commute by ebike at least the 9 mile one way commutes.
Will try to do the 19 mile one way commute (lots of traffic with areas of no shoulder) but it is not a must for the project to be a success.
Plan to use my mid 90's Trek 830 Mountain Bike for the conversion. It has a CroMoly Frame and CroMoly fork.
I have a speed goal of 20-25mph on flats and a range of 25 miles.
I am 150 pounds and will pedal some. I live in central New Jersey with modest rolling hills.
Although I know how to clean and lube a chain, adjust brakes and change tires, I am NOT particularly handy so looking for a very low degree of difficulty for my first build.
Parts:
- cellman 36v 500w DD Kit (front wheel)
- ping 48v 15a LiFePo4 battery. Through the forums, I have read that a 48v battery will work with this kit.
- upgraded 5A charger
Questions:
- Any issues with using the Trek 830 for the frame?
- Does battery just plug into the controller (connections ready to plug). Hopefully no soldering involved or additional connectors need to buy?
- Recommend tires? 90% pavement, perhaps 10% dirt paths. Can I use 26" narrower than usual tires made for pavement? Does the added weight as a result of the motor and battery affect tire choice?
- Bike does not have disk brakes. One of the reasons not going for a more powerful kit (1000w). Is this safe?
- Do I need high rate BMS option for Ping battery? Guessing no.
- Best place get torque arms and c clips? ebikes.ca?
- Bag / case for battery? Need easy removal and attachment to rear rack
Thanks in advance for your help and looking forward to contributing to the community once I know something.
My commute is:
Parts:
Questions:
