potatop
100 µW
Hello everyone! I got a backup battery from the local bike co-op and it seems to have been rewired to remove the locking mechanism at some point:
The large red and black wires (black connected to the light blue) are connected to the discharge terminals on the outside. The small red and black wires conmect to the visible charging port. What I assume to be the lock bypass is at the top of the image.
When I hook up the controller to the positive and negative terminals on the outside, nothing happens, but if i connect the negative controller terminal to the white sheathed wire inside (which the small black charging ground wire is connected to), the system fires up. Does someone know what the white and blue cables are, and how the charging/discharge grounds should actually be connected?
Thank you!!
Thank you!!
