Link
dogman said:Back to the subject of racks. Bear in mind that if you put the rack on the rear swingarm, it's sprung weight. I'm no expert on the handling effects of this, but this I know. I want my expensive as hell battery on the part of the bike that doesn't bounce around all day. Maybe it's not that fragile, but I do like the idea of the battery on the frame somewhere, where the shocks do some good to cushion it when I get airborne. I carry a 15 pound lifepo4 on a good seatpost rack and have no problems with it whatsoever after 1400 miles. there are about 15 water channels built into my bike trail route that become jumps when you hit em at 30 mph so it's not like I baby it. I doubt I could carry much more weight than 15 pounds, like if I tried to put sla's back there, but for a 15 pound lithium its ok so far. That small a weight, I barely feel it at all.
Unsprung weight. Not supported through the spring = unsprung. :wink: And, yes, that wouldn't be good for a fast ebike with even a relatively light pack. Just too much strain over a hard bump.
shinyballs said:If you don't mind having no rear suspension, a Rans dynamik pro is a good base bike. Ride is comfy and no need to dismount and remount at traffic lights, etc. Mount all the batts in the center frame, controller in a rear rack or behind the crank.
I don't like mounting batteries in a seatpost rack, even on a rear swingarm arm rack unless you like performing in a circus and turning your rear into a wiggle stick - like the battery mounting in the "High-Power?" Cycles bike .
That IS a nice bike. I'm afraid to ask how much it costs.
As a guy with like 45lbs of batteries and motor on the back of his bike, I can say it's really not THAT bad. Yeah, I'm sure DocB's pseudo-motorcycle handles way better than mine and I wouldn't want to try racing it around a twisty track, but you shouldn't have issue with it after you've ridden it for a while.
Still, if at all possible, get the batteries into the frame. It's just a better way to mount them. Period.
