999zip999
100 TW
Just one. Plug in neg then pre charge resistor then main pos.
999zip999 said:Just one. Plug in neg then pre charge resistor then main pos.
999zip999 said:That why I use a 5mm or 6mm bullet on neg end and the same on pos end with a extra pig tail coming from underneath both pos side with 4mm on each end with the pre-resistor. The combo of both neg and pos in one connector make impossible and you will burn out the baby resistor in that resistor.
Xt90s no good qs10 no good for your battery......
This is because you can't easily plug in neg then after pos s
Do want to fix your problem or ?
999zip999 said:Yes and will give a healthy spark but under the cover of the connector. Just plug in half way plug it in till display lights up then plug in fully. And let us know how long this connector last. Please. Good luck
As my 20s pack with xt90s just sparks now. I think I should install the pre-resistor on this pack. As I have two other 72v packs. Setup with pre-resistor.
999zip999 said:Wow that's 6 ga wire came pre solder ? They most be big
They have 10mm gold plated bullets on ebay
999zip999 said:The sparkling is hard the controllers caps as they fill up and could blow the top off.
16601804383776644572317470334476.jpg plug them in bottom to top. I'm using 5.5MM Mains my 72v is lower amps also.
999zip999 said:The three main wires black neg first next small red with pre resistor then main red pos.
I was just putting together a controller and took a pic. For you.
DogDipstick said:No.
QS8 and QS10 are recommended for these installs all the time.. but.. they dont cut it. It is silly, I have burned out or eroded all the contacts with those premade 5.6 ohm resistances inside them.
A QS8, 10, or XT90-s are ALL 5.6 ohms precharge resistor of like 2w rating .. made to precharge rc hobby batteries on the esc... at 22v nomninal. Low voltage. Only.
You have 5 TIMES !! that.. .... " 22v". you need a MUCH slower precharge than a 5.6 ohm 2w would provide. RC has small caps and tiny esc made for 22.2v .. Lol... You have 117v... a big controller... with some very big ( capacitance) capacitors... Especially with 200v caps ( that your 117v controller almost certainty has, ie big spark) .
Do the math. You can see how much faster a 6 ohm is compared to say.. A 100 ohm 10w resistor. Or use a 1000 Ohm 10 watt resistor. If you dont know the math i will lay it out for you . You want a circuit to keep the high current form hitting the controller and blowing up caps or sparking contacts.
1KOhm, 10watt.
A QS8 or QS10 is a band aid and does not protect the controller well and is not good for a long life in a system.
Use Precharge relays.
DogDipstick said:at least you got a cool black plug with a red line on it like all the cool kids) ..
Hummina Shadeeba said:
I had to get 20 sets. Write me and send u 4 for 40$ with shipping.
