DotScott
1 W
- Joined
- Feb 6, 2016
- Messages
- 52
Hey guys,
My controller (Sabvoton SVMC 96120) has been in use for only 2 months and all of a sudden, the motor started making a screaming noise and wouldn't go anymore. It's due to the controller I believe. The motor is still fine.
The controller will no longer stay connected to the computer application or the smartphone/bluetooth application. It seems to connect for just a second but displays all wrong information. The battery, motor, throttle, ebrakes, etc. are just fine. Just the controller is acting up.
I was only running 60 battery amps max when the controller failed so I was not pushing it hard (can handle 120 battery amps). Had been running fine for 2 months until this point.
The green LED on the controller does not light up - it indicates no fault. Just the red LED lights up and stays lit up as if it was normal operation. If I pull the throttle while on, the motor violently shakes - as if the Halls got misaligned. I can't do a Hall test though because the controller will not connect to the computer or bluetooth app. I also tried the second set of Halls on the motor: same issue.
System specs:
Battery nominal voltage: 86v.
Battery max charge: 96v
Battery low: 72v.
Max amps: 60
Motor: QS205 50H V3
Everything was working just fine but it suddenly just stopped when I gave it a tiny bit of throttle from an almost full stop.
Anyone have any ideas as to what's going on? I've reached out to Sabvoton and QS Motors multiple times but I never get a response from them.
System specs:
Battery low: 72v.
Max amps: 60
Motor: QS205 50H V3
