Howdy, hope things are well. I neglected to specify a temp sensor when ordered the motor above. So I think it is safe if I never operate the motor above 3kw. So it seems at 72V and around 48Amps I could run "all day" with not much issue. However I understand that this motor is quite capable of a bit more power. I am using the motor as a winch and I found it seemed to go well pulling a load with power at about 5KW. But I want to somehow monitor temp and observe how far I can push my luck (likely aim to 6KW). I thought of just using an IR gun/camera and observe the motor. So I figure the side covers wont heat much but would I be correct in focusing my observations on the axel, is that where the motor will most likely sink the heat out through from the stator ?
Alternatively I am using a VESC 100 250, I wonder if there are any electrical attributes I can observe when driving the motor that might indicate I am pushing my luck.
Thanks
Luke
Thanks
Luke
