I'm considering replacing the generic square wave controller with a KT sine wave controller on my DIY rear hub ebike (Bafang G020.500 motor, generic controller, DPC18 display). I'd also get the LCD-8H display, and program the parameters as it allows.
I have a question, though, about the assisted speed for each PAS level. It appears that I can change the power levels to an extent (low, medium, high) and that the ebike will get more power at each PAS level. However, it doesn't show anywhere (that I can find) about how the assisted speed will also change as I go up in PAS levels. The current Bafang system gets speed assist up to about 50% of the maximum speed in Level 1, about 60% in Level 2, about 70% in Level 3, about 85% in Level 4, and 100% in Level 5). And each level gets a higher amount of assist power.
Does the KT controller do the same? Or does the assist stay on all the way up to the maximum speed in every level? I wouldn't want Level 1 to stay assisted all of the way up to 28 mph if that's the maximum speed I have set on the bike. If the assist does cut off at a lower speed depending on the level, is it a % of the maximum speed, or something else?
As an aside, it appears that I would get either the 20a max controller or the 25a max (and limit it to 20a) for my 500w system. Any recommendations in that regard?
