querlenker
1 W
From the the tests I have made I can tell you that efficiency is much influenced from the gearing and wheelspin. Longer geared and more phase current (same torque on rear wheel as with shorter gear and less phase amps), lets you save batterie - that's what Luke tried to tell you before I think. I needed some time to find the best compromise in gearing and this is still track related.
Same with slip rate. We designed a device to control rear wheel slip rate. Before I did datalogging of rear wheel speed changes on several soil. It's unbelievable which short time peaks you get when traction is lost.. My system needs a lot of more tweaking as it is very hard to make it working on different track conditions. For example you go from hard track to sand track or from dry to wet. But the few times I had perfect setups in the device, it feels like you are on rails out of the corners and it saves battery and human energy a lot. Same for suspension, it will also save battery if it's a good one. For those who are interested in numbers, a small hole in the ground where you lose traction lets your motor rev from 2000rpm to max in a few milli seconds and increases battery current for more than 100A in this period of lost traction. Your bike isn't accelerating, just wasting energy.. Also you loose another few milli seconds when you get traction again till the slip rate come down. All those little things together decide if you are competitive or not in the end!
