Hi,
For my EBike project I would like to read the speed and torque signal from the T13 Thun Torque sensor using a ESP32. Have attached the datasheet for this.
Here is the setup with an RPS set at 12V: RPS- positive to torque sensor positive power pin and GND of RPS to torque sensor GND and also to ESP32 GND. Then took the torque sensor signal and set it on the ESP32 ADC pin where I read the signal with analogRead. (tried with ESP32 pins 2, 4, 34, and 36. All have same result - > 0 with no change after giving torque)
Here is the weird reading I get on DMM with different conditions:
No torque on sensor : 3.3V
applying torque clockwise and anticlockwise : 3.3V
So no change in the voltage from signal with movement. I have no idea what the protocol would be after this test. Could it be a defect of the sensor or anything wrong from my side?
- Problem is I'm getting 3.3 V at all the signal pins (speed and torque signals, pin 4 and 6 according to datasheet).
- I have used an RPS to power up the torque sensor at 12V (according to datasheet power range is 8-15 V)
