I have a Cab Motorworks Falcon, a Stealth Bomber style bike with a rear hub motor.
Recently I got a puncture, so took the wheel off, put in a new tube and reconnected the wheel, something I have done several times.
Now however, when I tighten the side nuts, the wheel will not spin freely. If I loosen the nuts, the wheel spins ok but its not rideable like that. I have checked everything I can think of.. made sure all the washers etc that were there before are back in the right place, have re-seated the wheel many times to make sure its sitting ok, centered etc. I have also removed the brake calipers to make sure its not the brakes rubbing. Nothing I seem to do makes a difference. its a constant grinding sort of sound, not a clunking which would suggest magnets inside the motor. Also the fact that it spins fine when loose means its mechanical somewhere.
Anyone got any idea what this could be?
