Thank you jairbj!! Problem now solved!! 8) 8)
I took off the rear adapter and connected AC voltage lines directly, and guess what...the power supply did NOT turn on, which is exactly the same situation as you reported. Logically, I started thinking the adapter must have some design error that is somehow causing the unexpected POWER ON behavior, and my testing described below confirmed this was, in fact, the case...the adapter has a critical design flaw! At least is does for the version of my power supply...R4850G2
I looked closely at +48v and -48v PCB traces on R4850G2, and I noticed the PCB design has changed (over time) compared to photos from other users that have previously been uploaded to this thread. Apparently, HUAWEI has changed the traces in the PCB from previous versions, but unfortunately the adapter that I purchased was not matched and suitable to the revised traces on the PCB.
I was able to find a simple workaround so I can still use the adapter, but also re-enable the START PIN function. I applied a KAPTON tape on BOTH SIDES of PCB traces on the power supply, actually on the top of the -48v traces.
After tape was applied, I reconnected the adapter to the power supply, and when I apply AC voltage the adapter works correctly. :thumb: To turn on the power supply is now very simple: GROUND only 1 of the 2 wires from the JST connector (the black wire). Note: Grounding the other JST wire (white wire) has no effect, so I leave it floating. The photo below will hopefully help others who have found this same problem.
Thank you again jairbj for your help and ideas, PROBLEM IS NOW SOLVED!! 8) 8)
