Simonvtr
Hi I am new to this forum and would like to apologized if i am posting this in the wrong place.
I've looked over my build for a week now and I am unable to determine what is the issue with my setup burning thru fuses while testing with no load on the trike just the weight of the trike and battery.
Its a custom warrior trike plans from AtomicZombie with some modification to the rear axle.
The motor I order from monsterscooterparts.com
I converted from chain to belt drive with electricscooterparts.com 95 Tooth Drive Belt Cog for 5M-15 Belts attached to a 20" rear rim with tires its 23".
The motor has a 15 teeth pulley on it that I had order from ebay.
The belt is also from electricscooterparts Belt Size: 1100-5M-15 (1100-5M/15).
With this setup my 40 amp fuse will just pop when I touch the throttle.
Is it due to my pulley ratio?
I ran it thru some online site
Belt Length 43"
Ratio 1 : 5.56
RPM Small 2400 Large 432
Belt (Surface) Speed 706.9 ft / min
Pulley Gap 11~25/32"
So wanting to test it i ran it without the fuse and controller burned up.
with the monster controller i had 6S x4 lipo 24volt 5000mah 20c in parallel giving me 24v 20ah.
Thinking it was a controller issue I went and bought this controller from electricscooterparts.com
with it setup for 24v I am still popping fuse
even with it setup for 48v and this testing is done with no load on the trike just the weight of the trike and battery pack.
Also does anyone know anything about SPD-60100a controller?
It has a weird clogging sound but stops when you have the throttle wide open.
Also with this controller the motor is getting hot. But not with the 24volt controller I had from monster that came with the kit.
Thank you
Simon
Belt Length 43"
Ratio 1 : 5.56
Thank you
Simon
