StressedOut
- Joined
- Jan 10, 2023
- Messages
- 23
Hello,
A little back story. I bought a second hand modded TSDZ2 for my delivery job, with what looks like the heat displacement mods, and firmware mods from the infamous Tongsheng GitHub page. After 4000km I needed to replace the blue gear, and in doing so didn't get a good reseal of the casing, and got moisture and grit inside the motor. So I'm going to buy a TSDZ2B instead and I'm struggling on how I should continue.
The TSDZ2 I have is using aluminium shims on one side, thermal pastes, and pads where shown on the GitHub.
It also came with a temperature sensor and internal fan, neither of which have actually ever worked. Im also using a 860c display. 48v 20ah battery.
I'm not using any customs heatsinks around the motor, as I've seen people creating.
I have a few questions.
If I install the proven heat displacement methods, and maybe a custom heatsink around the motor, I'd rather have a throttle, do I need to worry about installing a temperature sensor or internal fan?
I'm also not stoked on making a cut in the body to open the unused chamber. Simple fact that it seems that is where I lost the seal when replacing the gear. I'm assuming a fresh seal is necessary anytime you open that side of the motor, and I don't really feel like doing that. However, if that cutaway has proven to make a big difference then I'll do it. From what I understand the TSDZ2B has a better longevity and I wouldn't need to open it that much anyway. Some advice or encouragement on this issue would be appreciated.
I'm going to be installing a new drive train, and I currently have no brake or gear sensors, which I would like.
I'm using a SA internal 3 speed hub, with either 5, 6, or 7 speed cassette, friction/sis shifting. I want buy a Magura hs33 lever sensor with a red plug, and a gear sensor. It seems I only have yellow plugs on my bike.
I also have lights which I've never installed, but I would like to.
FYI, the only knowledge and experience I have with this stuff, is replacing the blue gear. All the firmware upgrades and soldering, wiring, I'm going to be doing for the first time. I'm ultimately a bit lost and terrified to start because money is super tight and I can't afford to make mistakes, and I'd love to just have someone in person that can show me what I need to buy and what to do so that it doesn't take out huge chunks of time a my finances. But I have no one local, or no anyone personally that works on these things.
Again whatever can be said helps.
Thank you.
Thank you.
