Hi all,
I'm working on running an RC ESC with a servo tester and twist-grip throttle. The problem is the throttle rotation range is less than 90 degrees, while the servo tester needs to rotate about 180 degrees for the ESC to reach full throttle. If I wire it up as it is, I'll only get about 50% of full throttle. I don't think the ESC can calibrate its endpoints down this far. I've done a lot of searching and can't seem to find posts about this specific issue.
I thought about using a pot with double the resistance (using a 20k pot instead of the original 10k), but - if I'm understanding this correctly - this won't work if the servo tester uses the pot as a voltage divider. So my question is: Is there a way to reduce the 0 to 100% throw of the servo tester from 180 degrees to 90 degrees?
