robby986
10 µW
I bought a bike from joe at green e wheels, now defunct, I think, in Melbourne Australia about three years ago. Used it to commute to work with it. It is a 36 volt system and it went quite well for a time until it stopped. I had it repaired and replaced the 13 amp 36 v li ion pack that didnt work with a 10 amp 36 volt battery which worked for a time but then succumbed to the same problem the motor cut out and would not go. I went back to using a much better and engineered technology -2006 Prius i tech. 106000 km -just change the oil! In the meantime I have lurked on the forums and hopefully educated myself a little and went back to looking at my sad e bike. I diagnosed part of my problem to a suspect power wire and made the motor run but it still cut out way too early. I mounted a multimeter on it and saw that the lvc in either controller or the bms was the culprit. Solution -buy ping 15 amp 36 volt pack with upgraded 5 amp controller and no voltage sag. Job done. I made a mock up of he ping, fitted a box on the rear of the bike and bought a cheap back pack to put he Ping pack in, but something was nagging at the back of my mind. If i bought the Ping i am sure that it would work, but I would still not undrrstand it. Just like my Green E wheels bike.
I have a Walkera lipo powered helicopter and was looking for some new lipo batteries and somehow or other fell over the hobby King site. What a revelation- Turnigy 5s 5000mah batteries x 4 3010b icharger, cables Turnigy watt meter p350 power supply paraboard all ordered on the internet and on the way to my place. This charger looks like it can charge anything and 30 amps- wow. Anyway i know that I probably wont be exploring the edge of the icharger envelope with my p350 powersupply but I am still very excited. 5 amps is a very long time to wait. Sorry Ping.
I was in my shed today and now that I know a very little more about batteries I decided to revisit my old allegedly buggered 36 v 10s li ion packs. The 10 amp had a voltage of 40.1 volts and it was made up of 10 cells in series with half the cells at 40 volts and the other at 40.1. i hooked up the 1.8 amp charger and it was happy to cut out and leave the cells at 40.1 volts. Does this sound correct to you experts? The other 36 volt 13 ah pack has 1cell that is reading .7?volts . All the others are at 4 volts. I am going to do two one while i wait for my Hobby King shipment. On the 10 amp pack I am going to remove the bms and use my Turnigy meter to monitor the voltage to see if I can avoid the low voltage cutoff from the bms by jumping or removing the bms and see if it is the controller that is cutting off. On the 13 amp hour pack I would like to see if I can individually charge the low volt cell with my 3010b icharger to get its voltage closer to the other cells or throw it away. I can see why you love e bikes everyone, i think I'm hooked!
Pardon me if I appear a little enthusiastic but for you younger folks I am 59 this year and I am still excited about the way we can learn on the net. I used to have to go to the library. Often someone else had already ordered the book, if it was there in the first place. Now it is on my I pad whenever I want it it. This is the life!
