Pota said:Okay, i now have 5v from all wires.
How does it spin two directions at the same time?Pota said:It is strange. Because when i disconnect the USB, i can give gas and the motor spins both forward and reverse.
amberwolf said:Pota said:Okay, i now have 5v from all wires.
1) what caused the change? (If you don't tell us *everything* you test and change, as well as the results of each of those tests and changes, we can't know what else to tell you without just guessing, which is usually a waste of your time and ours).
2) If you get 5v from *all* wires, then something is still wrong, because the phase wires and ground wires should not have 5v on them. There are probably other wires that shouldn't, either, like the throttle signal input, etc.
You'd have to check with the vendor or manufacturer for a complete list.
Or are you doing something that is causing it to spin one direction and then the other?
Or is it just doing it all by itself?
If you don't give details and exact steps, we can't know what might be causing the problem, because we can't know what the problem actually is.
amberwolf said:Then it sounds like there is one of these things wrong:
--phase / hall wiring combination (combo) is wrong. Easy to fix, if you go thru the various combinations; see the ES wiki article or various ES threads on how to fix this. If the controller has a self-learn function, try that first.
--Connectors or wires for the halls have an intermittent (or no) contact somewhere between the halls inside the motor to the controller's PCB. Could be anywhere in there, but the most likely place is at the connectors where they plug into each other, and contacts where they crimp to the wires. Close inspection usually reveals these if they exist, but may require an ohmmeter or multimeter on continuity, with power off to bike.
--halls inside motor could actually be bad, can be tested with a volt meter while controller is connected and powered on, and hand-spinning the motor. See the various threads for controller/motor troubleshooting for the specifics and procedure (or ebikes.ca has troubleshooting documents too).
amberwolf said:None that I can think of, other than trying a different controller.
Either the one you have is setup or programmed wrong (in what way, I don't know), or it is defective in some way.
I'd recommend checking with the vendor or manufacturer to see what they say.
