safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Framework For Front Fairing
The tolerances are just so tight on this part of the project that I'm looking to grow the front fairing out in a sort of organic process. These pieces provide a general framework on which the last parts will be added. The "hand cups" or whatever you call them need to cover just enough so that you get good aerodynamics and also allow for the handlebars to clear. It's a very tight fit.
Bicycle Specific Feature...
On a motorcycle road racer you never need to get up off your seat and pedal. As a result of this you can allow the front fairing to slope backwards over your hands. This means that if you try to stand up the fairing will be really close to touching your hands.
On a bicycle you need a little extra space because when you pedal you tend to wiggle around and tip the bike from side to side, so as a result of this I'm going to taper the part where the fairing goes above the hands a little earlier than normal. This will allow extra hand clearance and when I make a bike that is pedal powered (this one will have no pedals) the fairings will work well with them. The rear fairing might actually be a bit tight as far as the pedal clearance, but I can always take a slice out of the middle and narrow it if that's a problem. (the only way to know is to try it)
