RLT
OK, Never mind.
I was just relaying my personal experiences, hoping to help you make a great machine; Just my way of of giving thanks for the information and ideas you and the others here have given me on my projects.
I have no desire to make and sell spot welders nor to start building battery packs commercially, although I would have been willing to help people here out with a few welds occasionally and to provide the information on building their own welders if they want, assuming that either of my devices do a good enough job, which is far from certain at this point.
Here is just one quick illustration though: of the 18 NiMH C & D cell batteries I have sitting on my counter now, here are four that have dents of significance These are all merely from the pressure of the spring pushing the + battery tips into the negative base, in MagLights under fairly normal use. The ones that actually sarted leaking were in lights that saw rougher use... especially if they were dropped either base first or head first and had the full force of the impact mostly perpendicular to the base plane of the battery. (Sorry, but I didn't keep the ones that were badly damaged around to prove it.)
Now admittedly, these ARE Powerizer batteries which don't have the greatest reputation for quality in the world. Maybe other brands are more stoutly built.
And of course flat top batteries don't have the projecting + points, so pressure from springs and/or impact would be more widely distributed, and less likely to cause problems.... But then, making proper contact using flat tops without tabs is even more of an 'engineering' problem.
EDIT: Oh, one thing I just now thought of , and it is kind of embarrassing
that I just NOW thought of it instead of a couple of years ago. The ones that actually started leaking may not have been due only to a mechanical stress failure of the battery case, but it is quite possible that the dents made the batteries short out internally and overheat. There was no significant bulging of the cases, or melted shrink wrap to make a short seem self evident, but t could definitey be a contributing factor.
If you think I'm a lying troll just trying to cause you trouble or make money off of you, there is no point in continuing this discussion and I'll go elsewhere.
And with that I'll wish you good luck on your project and hope that you discover that you were totally right and I was totally wrong, and thank you for sharing your knowledge and your discoveries with everyone.
![battdents.jpg](/sphere/proxy.php?image=http%3A%2F%2Fwww.az123.com%2FCPFstuff%2Fbattdents.jpg&hash=49626bd96fbf5a3651de78b4ed80dbb9)
![Oops! :oops: :oops:](/sphere/data/assets/smilies/icon_redface.gif)
