Abhineil46 said:Yes great power discharge rates.
But not great lifespan. 30Q is worse though, per Pajda 40T gets 1000 cycles at 100% DoD with 63% of initial capacity left.
50E is **much** lower power discharge, maximum continuous discharge 2C (9800mA) and 3C (14700mA) not for continuous discharge,
but if that is not critical, can build higher Ah capacity, then with the same test 1000 cycles leaves 85% capacity, may last twice as long![/u]
Again, designing for high power density (C-rate) is in opposition to high energy density (mAh storage capacity). Neither one is good or bad, just depends which is more important for **your** use case.goatman said:are you considering the 40T a 10amp 4c cell with 4000mah? im running 25rs also. if you are then isn't the 40T better than a 25r? you mentioned 5c destroys a 25r.
by weight a 30q and 40t are equal and you get less with a 25r
You will get a **huge** increase in longevity by reducing your average capacity utilization.eMark said:My guess is that the main (only) advantage is twice as much ebiking mileage with no advantage in increased cycle life longevity with a build of higher Ah capacity (e.g. 10S10P vs 10S5P) no matter which same identical 21700 cells are being compared (2P vs single cell) whether 40T or 50E cells. Right or Wrong ?
goatman said:if that's the formula and 3c is max discharge for longevity of a cell. 3c is 7.5amps
so 4p of 40T at 3c is 30amps and 16ah and I should get a 1000 cycles if I keep the batteries below 50 but I could rig a fan or divert air to keep the core-temp of battery at 40.
You see, as long as the word "damage" is subjective it is pretty useless. There is no bright B&W line with longevity, it's a matter of balancing the many variables in each use case, all greyscale and sloping curves, owner's preferences and wealth just as critical as anything technical.goatman said:as long as I don't overheat the battery why cant I run upto 12.5 amps through this cell without damaging it.
has anyone done a 10 amp discharge with a fan blowing on the cell?
This is typically my usage as well and my experience is that those always varying operating conditions make a big difference wrt datasheet performance.rg12 said:docware said:rg12 said:Thats very interesting!
Is that from the datasheet?
I would like to know the temps for about double these currents for about 1 minute constant
It´s my measurement.
1 minute is too short time to see the temperature change on the surface of the cell. Can you describe intention of such measurement more extensively ?
My most common use is high powered ebikes where nothing is constant current and it all works with bursts and even full throttle is not max current since it settles at max speed so about 1 minute at max current is the max my pack will see in addition to some cruising with full throttle bursts.
Where can I get that cell holder and what equipment do you use for testing to create the charts?
