scorpion fx
goatman
Surrey, B.C.
I bought this bike for commuting in the rain/cold, 20 inch tires rear suspension.
mxus xf40 DD
ca3
phaserunner
2-14s4p 25r in parallel
2- 2 person tents
im still playing with the canopy but it does the job at keeping me dry and the cold wind away. adam333 and his kmx trike here on ES is where I got the idea of using the tents
[img
][/img]
ill post more pics later but I have a hitch on this bike for a bob trailer. ive found that when im using the trailer it costs me atleast 10 percent of my range.
hitch for bob yak trailer. this is the bracket I was playing with, its made from 3/16 aluminum angle. I was trying to keep the bob nutz as high as possible and as close to the axle as I could without the rear rack hitting the trailer. the rack is bolted to the frame independent of the swing arm. now im going to make that out of solid aluminum as a clamping torque plate hitch
I bumped my battery to 17s and wanted to see how the motor handled the voltage. no problems with the motor at that voltage. I couldn't do a topspeed run, it was windy and my windshield was bowing inward at 50km/h so I backed off.
I think with 2 of these batteries ill have about 100km no pedal range.
I need to get a different battery box. this one is 14w x13d, I cant really pedal without the legs hitting it but a dewalt 1/4inch impact driver case is about 16w x11d wich will fit the batteries and clear my legs
I used 1/2 inch pex 90's and tees to put the tent poles together, nothings glued and the plexiglass is ziptied on.
I used 2 plastic hooks with the bungey chord to keep the canopy secured to the nose cone.
I plasti dipped the sides of the battery and the battery wasn't any hotter than my other batteries, it was actually cooler. I need to change the wiring so I wanted to see what kind of mess the plasti dip caused. none, it peels right back
looks like I have some fixing to do. the tent I used had 1/4 inch fiberglass tent poles. the wet snow broke them I guess. ill try to find some 3/8 fiberglass poles since the smaller pole is only good to about 50km/h
the roads were a mess today, snow, slush and flooded roads
the last pic is the phaserunner, I had to take the fender off to fit the fender 2 days ago and hadn't had a chance to make one. that phaserunner got pelted with water and slush non stop without any issue, impressive. so make a fender tonight.
trikes been running great, switched front tires to maxxis holy roller 20x2.20 at 25psi. share some pics of the ride to work today. 39km to work from Surrey to Richmond.
wider battery box fits 2- 17s4p of 25r
pannier bags with my gear and charger
view from where I live
king George hwy bike lanes
Alex Fraser bridge over the Fraser River
looking up the fraser, new Westminster to the left, Pitt Lake would be out by the mountains
Annacis Island
wild life
Westminster hwy heading for Richmond
10 minute train delay
LaFarge Cement out in thr farm land
wheres all the bikes?
north shore mountains
farmers farming
frign path got tight
almost there
Juicing up from the neighbours
let it charge for 1.5hrs@ 5 amp charge
used 7volts to go 39km
no planes in the sky above Vancouver International Airport
took a scenic route on the way home
got a glitch on the ca3, kms are off should've been about 78km and top speed is usually 65km/h not 654?
sometimes I pull a trailer, I can fit a Milwaukee grease gun perfectly in the bob-yak and a dewalt 079lr in it no problem, just need the grease gun today
was doing 60 and heard a noise, trailer had a flat
I pumped it up hoping id make it to work but nope had to stop by scott rd skytrain and fix it.
I use the cover from a tent to keep the rain, sun and dust off
I didn't take pics last night of trip but I think I was at 61v, I just grabbed another battery to turn on trike for trip display
the forecast was 1mm of rain through out the day. it only takes 2 minutes to put the "rain gear" on the trike
glad I did it was raining pretty good on the way home, my shoulders are the only part that gets a little damp and my right hand.
Nice ride!
We've got a pair of Scorpion FS26's with MAC power. Getting to the time of year that we either have to ride in the evening or early morning at sunrise.
A few pics on this page:
http://www.triketech.com/Drivetrain/PowerAssist/HPV-MAC-V2.html
Triketech said:
Nice ride!
im envious :D i wanted to put a 26 inch rear on this trike so contacted HPV about buying your trikes rear triangle, they said dont. i see you run the phaserunner :thumb: and MAC. i havent enabled the regen on the trike because I didn't want to stress the rear pivot/suspension point. it gets lots of attention, on Friday it was sunny and a guy rolled down his window at a light and asked how fast? I said 65 if I wear a speedo :lol:
goatman said:
i like skrohod, not too sure what he thinks of me and markz though
I haven't bothered with reading what you post there. Are you trolling him? Just because you're not as bad as some others doesn't mean it's not bad.
no im not trolling him, cmon :) but I did send him what I thought was a funny youtube clip about a Russian gold miner but i think he thought i was serious. oh well. but im going to leave my humour out of his thread for now.
I bought some tires, I got a shinko 214 sr 16x2.25 moped tire but it was too big in diameter to fit the rear triangle.
I got 3 Atlas Fiction Night Moves 20x2.30 tires with yellow 3m reflective from Chain Reaction Cycles in the UK
still on the factory rims
I put a moped 16x2.50 tube in the rear and bicycle tubes up front, these tires are nice, theyre fast and absolutely silent, sidewalls aren't thick but theyre strong. theyre not the thickest tire were the tread is but theyre nice and light, going to keep looking for a rear tire, there is room to fit a 20x2.50 in the rear be nice to find a slick with a 1/4 inch of rubber or more,
