SKATEBOARD video & gps 23 mph
Just so you know, you've been featured on hackaday.
Nice work, bruv.
http://hackaday.com/2013/08/10/diy-23mph-electric-skateboard/#more-100894
My new 24" board should be interesting
Did you change the wires coming from your motor? Can you do that without damaging the motor?
Yes, you can change the connectors coming from your motor by soldering it off and soldering on different ones. I prefer using 5.5mm gold bullet connectors. If there is a 3mm or 4mm gold bullet connector, I'll cut the wire and solder on new 5.5mm gold bullet connectors.
Snowboard cut down
For my small board
i am also building an Eboard with two motors and i was wondering what the component to the left of the battery was in your latest design. I was also wondering if you could tell me what the component is used for so i can finish my Eboard.
also where did you get the gear that you put on the wheels and shaft of the motor. Did u make them or order them online?
papo2110 said:
Silenthunter said:
Papo,
How much range do you get with the Headway 8 cell pack that you have on your aluminium board? How long does it take to charge it?
I get around 7 to 8 miles around Central Park
There are some steep and long hills
And how many time for charge them? More batterys? More time to roll?
Very well Papo, congratulation and thanks for this post, and thanks to all the aotherone here for wrote their expieriences... :)
THX a lot
working on a smaller transmitter will strip down and put in to a smaller 3D printed case
should be fun
CUT TRIM TO FIT REMOVE PART THAT ARE NOT USED
11111.jpg3D model ready for print lots of work
