Slipstream
Thanks for the feedback, John.
The ISDT Q8 unit...
First problem ... non standard balance port header... standard JST cable won't fit.
My solution ... burn out the non standard blocks with a hot probe... then add a standard male/female cable so the port itself takes less abuse when the balance cables are plugged/unplugged. Until I get one of these made I cannot check the balance function, but in all, so far, I like it.
Second problem ... there seems to be no way to open the unit up ... yes I looked under one of the tiny feet pads... no way to remove the cover and look inside... so what happens if the $1 fan gives up? yep.
The ISDT Q8 unit...
