I hope this is the right section for problem solving. I am having a problem with my Bafang motor. I'm unsure where the problem lays as the problem is a bit strange. If a turn on the LCD display it will not come on unless the charger cable is connected to the battery and the charger turned on.
If you disconnect the charger cable the LCD display turns off. I have disconnected the battery and held the LCD screen on button down to effectively do a 'reboot', then reconnected the battery but the problem still continues. The fan in the charger no longer runs when connected to the battery and the LED lights don't change ( now always 1 x red & 1 x green, was both red when charging ), so it doesn't indicate that it's charging. Can you give an idea what to look for or tests to run to diagnose which component is faulty?
