migueralliart
30mph is a good speed I hope it doesn't end like the outlaw ss which is no longer for sale I heard.
cal3thousand said:miro13car said:at first look you might think, circut boards with capacitors and components inside motor?
What this electronics going to be subjected to!!!
But no ,
it can last for close to 24,000km on my Tidal Force
Exactely 23,854 km as of today.
If designed and manufacture with quality can last thousands and thousands of miles.
You are basing your arguments on anecdotal evidence. Your sample size of 1 bike is ridiculously low for you to be able to speak about the motors' general reliability.
Green Machine said:I have a friend who is the lead ebike mechanic at blazing saddles with a fleet of stromers and a2bs. According to him they send failed motors back on a regular basis for replacement.
I always get his opinion on how reliable these systems are since they are putting many miles on many bikes every day. This is in SF hilly conditions.
And what is the purpose of having controller and hub built into the wheel when you have such a nice big hollow downtube you can fit both battery and controller in?
50yearoldebiker said:I'm pretty sure you could order the bike with a throttle & front suspension from Stromer, I know I would.
Dan,
Thanks for your interest in Stromer! There is, unfortunately, no throttle kit available for the ST1, but there does exist a push-button Boost Mode that will act similarly to a throttle up to 12.5 mph. However, for the most part, this bike is by choice pedal-assist only.
You should give one a test-ride if you have the opportunity. This would likely be an endeavor for a mainland trip, however, as we don’t currently have any dealers in Hawai’i. I say that only because I didn’t care much for pedal assist until I rode a Stromer, after which a throttle seemed completely superfluous.
Best Regards,
Peter Wong
Technical Support Representative (West Coast)
peter.wong@bmc-switzerland.com
Tel 415-785-3490
Paul_G said:Picked up a Stromer 3 weeks ago to replace my Stealth Bomber
mattrb said:Paul_G said:Picked up a Stromer 3 weeks ago to replace my Stealth Bomber
Should've just bought a schlumpf. It would've solved the problem with the bomber being a bad workout. I have a schlumpf phasor and it is a great workout.
Paul_G said:I thought I was getting a workout on the Bomber ( I would peddle at all times) as well
mattrb said:Paul_G said:I thought I was getting a workout on the Bomber ( I would peddle at all times) as well
I guess you haven't ridden your bomber without power too much. That must be a workout. It certainly requires effort on my 85lb bike. The schlumpf gives you cadence at high speeds that you love on the bomber, the same cadence that you get from the stromer. You could also have done pedelec or cruise control on the bomber too.
