torqueboards
Best way is to install an amp/watt logger to effectively know.. Boosted is using most likely 42mm motors, although custom. You won't be able to get the custom motors one off so your best bet is 50mm motors.
Hummina Shadeeba said:How do u find the handling? Does a single motor send u a bit sideways? It seams if a single strong, possibly front, motor could get braking done and there weren't any handling issues it'd be nice
Silenthunter said:I agree with the above but with the dual 6374-192kv a get insane acceleration and braking. The board is much more stable and has more control. I notice after 1 hour of riding that there is no more pain in my feet. Probably less vibration or I don't know what is it by is way more comfortable. Motors were placed diagonally.
Silenthunter said:Are you are referring to the drag of the belt/motor? If yes, than my construction is similar to lagrange and even if you want to push the board there is no restriction/drag. The boards moves freely with both or single motor.
Hummina Shadeeba said:What's the benefit of the spinning axle?
Is your motor is on the left rear truck? On single drive, the driven wheel can be lifted on very tight turns, especially if you have wide trucks. Thats why on e-mtbs, dual drive is almost a necessity.brent said:Wouldn't consider it a handling issue, but I had some issues with the drive wheel slipping when turning.
A little annoying but it was only really a problem when riding uphill on a path that had a lot of tight right turns, haha.
So why do they bother? Wonder why complicate itpsychotiller said:Hummina Shadeeba said:What's the benefit of the spinning axle?
The spinning axle doesn't have anything to do with the lack of resistance from his motors while pushing. A couple of my boards have pretty much no resistance while pushing. One of them is a Lagrange. The spinning axle was a good way for Lagrange to attach their Wheel pulley. It seats into the wheel hub which is epoxied into one wheel. The other wheel spins freely on its bearings. If they had bolted their wheel pulley to the wheel, they wouldn't have had to epoxy a split hub into the drive wheel.
Hummina Shadeeba said:So why do they bother? Wonder why complicate itpsychotiller said:Hummina Shadeeba said:What's the benefit of the spinning axle?
How's front wheel drive?
psychotiller said:My riverbed board http://endless-sphere.com/forums/viewtopic.php?f=35&t=60449 is front wheel drive and I'm digging it.
beto_pty said:psychotiller said:My riverbed board http://endless-sphere.com/forums/viewtopic.php?f=35&t=60449 is front wheel drive and I'm digging it.
Front wheel drive rocks! also the dynamics of impact are changed.... you dont slam into stuff.. you roll over stuff..
psychotiller said:Yup! I guess the point I was trying to make is that the floating axle doesnt matter. Their pulley is mounted to the axle, and is connected by belt to the motor which completely eliminates the floating axle and any absence of resistance. The only way it could be considered a floating axle is if it wasn't connected to anything. You can call it a floating axle all day long because without the pulley and hub it is. But as soon as you bolt something to that floating axle it sinks.
