Offroader said:How much does voltage matter for a mid drive bike?
I was under the impression that it wasn't as big of a deal because we can control the gearing?
motomoto said:I just ordered 4 Zippy 2S 8ah batteries to parallel and series in to get some more volts with a stock setup. I am thinking that
2 batteries on each side of the battery pack in between the frame tubes. Maybe a plastic cover that holds 2 batteries on
each side with the edges tucked inside the frame. Batteries and plastic cover held in place with industrial strength velcro.
fechter said:I was able to do a quick ride between rain storms. Below are the CA screen shots. I started with a full pack, hot off the charger.
At the end of the ride, the Sur-Ron battery meter was showing 45%. Ride was all sport mode and I took off hard at every stop.
You can see the pack voltage sags quite a bit at full current.
The current limit would start out at about 77A and slowly rise if held at the limit for a long time. This may be due to heating in the shunt (artifact). On accelerations, I was seeing numbers mostly around 4500W.
I also re-measured the full speed, no-load current with the pack fully charged, hot off the charger and it was closer to 14A, 900W but dropped steadily as the pack voltage started to drop.
I was too lazy to try taking the belt off, but I did take off the chain and it measured about 750W at full speed. So the chain and windage from the rear wheel take up about 150W at full speed. I verified the brakes are not dragging at all.
ziltoid81 said:over 70wh/mile holy sh....
I doubt i ever reached that consumption with my hubbies, even with more volts and amps.
Will do a hard ride home after work and measure what my MXUS will do with 100A/240 @ 20s when i go hard.
Thanks for the measurements.
n2mb said:This is with the stock controller? That's a lot of amps. I'll measure the X controller this week... I think if it is only 83A, I'm going to return it. What's the point of gaining a few amps, no regen and no speed increase? It's not much quieter either. It still makes a lot of noise once you get moving. It doesn't seem worth $500...
Hot off the charger, it was around 50mph, but my speedometer isn't exactly dialed in. Probably closer to 52mph in reality. When I was running wide open on flat ground (40mph), the current was close to the limit, so it may be power limited.n2mb said:What does your display indicate for top speed with the tire in the air? I get 52 MPH, so it could be power limited at top speed.
JASdidit said:Luna Cycle has the Sur-Ron X bike on sale for $500 off on Cyber Monday, and I'm thinking about getting one.
bigbore said:ziltoid81 said:over 70wh/mile holy sh....
This is what I have when I ride the in the hardest way I can with my QS205 and Max-e controller and 20S14P Sony VTC6:
54Wh/Km = 86Wh/mile
Offroader said:bigbore said:ziltoid81 said:over 70wh/mile holy sh....
54Wh/Km = 86Wh/mile
Damn that is a pretty darn high but you are pushing 12KW. Do you have serious over heating issues where you have to stop riding to let your motor cool off?
I get 36 Wh/KM or 58 WH / mile on my 8KW bike and that is pushing the bike pretty hard with max-e and MXUS turbo.
That's how to win!
Remember to keep your motor phase leads short so the inductance the controller experiences while tuning matches (or close) the representative system inductance. Im excited to see if it can break 30hp with enough tuning.
3DTOPO said:I just got back from my first snow ride.
3DTOPO said:I just got back from my first snow ride. A few inches of powder made for an interesting run!
Offroader said:Can anyone comment on how well the rims are built and if the wheel build is true.
Do any of the spokes loosen up?
Do you find the 12 gauge spokes more than strong enough for the bike?
Offroader said:3DTOPO said:I just got back from my first snow ride. A few inches of powder made for an interesting run!
Nice. Great to still have that ebike enthusiasm. I remember when I was new to ebikes I would bring the bike out in freezing temps all the time. I even bought heated electric grips which made a huge difference in the cold.
I found 40 degrees to be the cutoff where above it was easy to ride around, below 40 degrees it was a bit too cold.
