skyungjae said:Wow. I'm going to get the same tires when my OEMs start wearing low.
Did your top speed in sport drop at all?
Did your mileage get better or worse?
Did you get your plate?
It's hard to tell. Since the wheel is bigger, the speedometer will read lower for the same speed. Downhill or with a tail wind the motor tops out at the same RPM as it did before but the bike will be going slightly faster. I don't think it makes a huge difference. Like equal to 1 or 2 teeth different on the rear sprocket.
The mileage indicated by the display will be less since the odometer will be off and the motor can draw a bit more current at top speed. I need to carry my GPS on the bike to see how much it affected the speed reading. I suppose I could also measure the circumference and compare it to the stock tire.
For street use, the high gearing works out OK. For off road, a larger rear sprocket would be good. Most of the streets around my area other than the freeway have a 35mph or less speed limit. I can easily keep up with cars on these streets, and they all speed.
I'll also say this thing is a real head-turner. When I'm passing by, people look at me with that WTF? look on their face. I think part of it is the noise it makes.
